Author Topic: E Brake Cable Melted  (Read 5574 times)
Offline 74GMC
« on: December 28, 2011, 10:11:52 am »
Awhile back I was driving my truck pretty hard and the exhaust heated up allot. I have dual 3" straight pipes coming off headers, flowmater 40 series mufflers. My E brake cable hangs on the exhaust where it  Y's and crosses over to the passenger side frame rail. I replaced the cables recently and don't want that to happen again.
Does anyone have any ideas on what I could do? I was thinking of a exhaust wrap, like the ones you see on dirt bikes. Not sure what to do.
"Nothing Beats a Chev"
Offline bd
Re: E Brake Cable Melted
« Reply #1 on: December 28, 2011, 10:53:51 am »
Roll a double wall 18-16 ga steel shield with a sheet of fiberglass sandwiched between, and clamp it to the exhaust with about 3/8" inch air gap.  Or, you can buy one pre-fabbed.  Then add a heat reflective tube around the cable (various choices available from Summit Racing, et al).  I had to shield my speedo cable because of exhaust heat.
« Reply #2 on: December 28, 2011, 10:56:32 am »
re-route the cable.
« Reply #3 on: December 28, 2011, 11:39:03 am »
re-route the cable.
     Why take the hard road when the correct road is simpler and you won't add stuff to your truck that is not suppose to be there.
Offline 74GMC
« Reply #4 on: December 28, 2011, 12:27:28 pm »
I would like to re-route it, but the cable is the older style that y's just below the drivers side then crosses over. How could I re-route it.
« Reply #5 on: December 28, 2011, 01:12:59 pm »
re-route the cable.
The correct road is to reroute the cable. From the factory they re-routed the cables depending on driveline configurations and they accomplished this through the use of cable guides that are supposed to be there. It's simple and retains the factory look. Take a look at the attached, the curled end rods are cable guides and you can buy universal ones as well to keep them away from exhaust/driveshaft etc.
Offline bd
« Reply #6 on: December 28, 2011, 01:25:00 pm »
re-route the cable.
Very good advice!  BTW: The problem with exhaust "wraps" is they trap moisture and accelerate rusting; not a good thing with mild steel pipes (wraps can actually void header warranties).  Good luck with your project.
Offline 74GMC
« Reply #7 on: December 28, 2011, 01:38:13 pm »
Thanks for the suggestions. My e brake looks like the C model pic on the right, except mine is missing that long cable guide that passes over the crossmember.  I'll try that setup and see if it helps.
« Last Edit: December 28, 2011, 01:40:35 pm by 74GMC »
