Fuel Systems and Drivability
chevy pick up fuel lines
Topic: chevy pick up fuel lines (Read 27282 times)
dagwood
June 07, 2013, 12:22:42 am »
hello. i have a long wheelbase chevy half ton 4x4. i'm not exactly sure what year it is. but when i got the truck, it had the fuel lines removed and a electric fuel pump with a rubber hose going to a plastic gas can. i was wondering how was the fuel lines routed from the factory. i would like to recreate how the lines was when the truck was new. thank you for your time
Blazin
Blazin new trails!
Re: chevy pick up fuel lines
June 07, 2013, 12:41:59 am »
Down the pasenger side frame rail. Then depending on if it was dual tank, or single tank. It could run to the tank selector valve, or up and over the top of the frame behind the rear cab mount to the sending unit. Or if its drivers side tank across the rear cab mount cross member and over the top of the frame to the tank sending unit.
dagwood
June 09, 2013, 12:12:40 am »
thank you, i just found out on here that the truck was a 1977 model
June 09, 2013, 12:29:37 am »
i think it was in 1980 is when gm moved the tank to the passengers side
werewolfx13
Site Supporters
June 10, 2013, 12:08:21 am »
My '76 has its tank on the passenger side, and my '83 is on the drivers side..
Chris
'83 Chevy c10 Silverado SWB
74 C-10 Shorty
June 10, 2013, 08:07:48 am »
My 74 is on the passenger side..
June 11, 2013, 11:35:44 pm »
lol it was late and wasnt thinking but in 1981 is when it moved to the drivers side. that post should of said "moved from passengers side"
74 C-10 Shorty
June 11, 2013, 11:45:29 pm »
Now that that's all cleared up, LOL...
June 11, 2013, 11:50:50 pm »
lol
Stewart G Griffin
June 12, 2013, 08:17:30 am »
This is one area that you definitely want to get right.
Last Edit: June 14, 2013, 11:43:36 pm by Captkaos
74 C-10 Shorty
June 12, 2013, 08:40:00 am »
Quote from: Stewart G Griffin on June 12, 2013, 08:17:30 am
For sure!..
dagwood
June 12, 2013, 11:09:37 pm »
thank you..i hope to copy what the factory did with the fuel lines, when they built the truck.
June 12, 2013, 11:20:56 pm »
its not that complicated just make sure you bolt them down and they dont rub on anything. then connect point A to point B
74 C-10 Shorty
June 13, 2013, 08:13:54 am »
Just a tip for anyone doing their own custom lines, this stuff is easy to flare and bends by hand makes it very easy in tight spots and comes in bulk rolls..
http://www.autoparts2020.com/rsdev/part_group.jsp?PHPRJ_GROUP_ID=56211
Last Edit: June 13, 2013, 08:16:08 am by 74 C-10 Shorty
June 14, 2013, 11:44:20 pm »
Inlinetube.com and classictube has prebent lines for our trucks. I have used both company's products.
