I was wondering if there is a difference between TH700R4 transmissions in 2wd and 4x4 models or are they all the same?
Any 4x4 transmision has a shorter output shaft than a 4x2 trans. Unless you are talking old school / divoced transfer cases.
Reading into the question... If you want to use a 2WD trans on a 4WD or vise versa, you have to pull either down and change the output shaft Blazin is talking about.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
