73-87 Chevy _ GMC Trucks > 73-87 Chevy & GMC Trucks
What is this
Mike81K10:
Might be A/C compressor switch. Being on the DS of carb is about where the compressor would be if you had an A/C system. Just a guess!
bd:
That air temperature switch inserts through the side of the air cleaner housing and is retained by a horseshoe spring clip. It is part of the AIR emissions package (smog pump) control circuit. The switch contacts should close above ~60° F.
wz7u:
That makes perfect sense, I see the clip groove now.
D'oh!
86c20RN:
Thanks so much for helping me. I will try to see if I can find the spot it goes in.
Navigation
[0] Message Index
[*] Previous page
Go to full version
