73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: SK468 on February 17, 2004, 10:46:00 PM
Hello everyone I have a 14 bolt and it's an open differential, what's the cheapest way to get a posi or locker in there? If you know of sources that would be helpful.Thanks in advance!!
Detriot locker is the cheapest to get, but are getting more expensive. I believe that you can get one new for about $350 if you shop around, they were about $300 a year ago. It replaces the spider gears inside an open differential. If you have a carrier from a 14 bolt that originally came with a gov-loc then you will need to find a new carrier.
*edit* I forgot to mention that this is for a full floating 14 bolt only. 1973 K20 - 350/465/205
Edited by: 73K20 at: 2/18/04 8:56 am
Are you talking about the powertrax locker? That's the one that goes inside your existing differential, last I looked through Jegs they wanted $450 for it. If you know of a cheaper source for one I would be interested, thanks for the help!! Ohh and my 14 bolt is an open diff and it's a full floater as well.
Check out the No Spin/Detroit Locker.
Thanks!!!!
