73-87 Chevy _ GMC Trucks => Interior & Equipment => Instrumentation => Topic started by: hladkib on August 29, 2023, 07:39:32 AM
Hey All,
Long time lurker.
I'm trying to find the correct speedometer gear housing, but I have failed twice to order the incorrect part.
I have a 700r4 and want to update the drive gear to correct my speedometer. I did all the math and calculations and have found that I need a 44-tooth drive gear. I have ordered a part from Summit, having to wait months for it to arrive only to find that the OD of the housing is incorrect. I found one on eBay it promptly arrived and that is the wrong size.
My question is: What speedometer housing do I need? My current speedometer gear housing measures 1.93" and the ones I ordered are 2.07"
Summit Part
https://www.summitracing.com/parts/TCI-880023
Ebay Part
https://www.ebay.com/itm/175116843392
Install it without the seal and see if it fits. If it does the housing is probably crusty.
2.07 is correct for a 700r4 with a mechanical speedometer. Is it possible that you are using a tail shaft housing for a 700r4 designed for an electronic speed sensor?
