Author Topic: 85 chevy crew cab 1 ton brakes not fitting.  (Read 3219 times)
Offline thelincolnguy
« on: June 27, 2016, 12:01:19 PM »
hello i have an 85 camper special with pin type caliper spindles. bought the truck with no front brakes and bought new brake rotors/ pads/ bearings/ calipers. calipers fit without the pads but when trying to install pads it seems as if the pads or rotor  are too thick. even tried the 3/4 ton truck pads still not fitting. can post pic if needed. thanks!!
Thelincolnguy
Offline big_al273
Re: 85 chevy crew cab 1 ton brakes not fitting.
« Reply #1 on: June 27, 2016, 06:36:36 PM »
are the pistons in the calipers compressed? if they are extended they can cause what you seem to be describing
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 GMC K1500 winter beater
« Reply #2 on: June 28, 2016, 11:50:12 AM »
yes they are brand new calipers with the pistons fully compressed.
Thelincolnguy
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: June 28, 2016, 11:53:04 AM »
They apparently make 2 different sets of calipers/rotor sets for the dually, so the parts guy probably screwed up and gave you the thicker rotors, but the calipers for the thinner rotors. Is your rotor about an inch and a half wide?
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
« Reply #4 on: June 28, 2016, 03:24:36 PM »
Yes rotor is exactly 1.5. And truck has the pin type caliper mounting. Had slide spindle on one side when i bouthg it. But i found another pin type spindle and installed
Thelincolnguy
« Reply #5 on: June 28, 2016, 09:09:54 PM »
I realize I wrote dually, I meant 1 ton, but my brothers 86 was the same way, I'll try to find the part numbers for the rotor changes and caliper changes
« Reply #6 on: July 24, 2016, 08:06:38 PM »
Ok. Thank you!!
Thelincolnguy
« Reply #7 on: July 27, 2016, 01:09:38 PM »
what am i missing? it should have the shim type for the dana 60 which should be on most 1 tons. take some pictures if you dont mind
« Reply #8 on: July 30, 2016, 08:01:16 AM »
Ok tim give me a couple days to take pics as i am moving currently
Thelincolnguy
