Needless to say, something just isn't right to go through all those pumps. Are you sure the pump rod is seated correctly? Is the crank shaft of the engine the same in all cases---hitting it correctly? Or, are all the pumps coming from the same batch (same store, etc.)
Are you sure it is your pump? I am not sure, but will a crack in the intake do the same thing--put gas in the oil? SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
diaphrams dry out on pumps that haven't been used in months. Just like carbs dry out. All seals would need to be replaced. SgtDel
aka "Andy"
www.delbridge.net
