General Site Info > General Discussion
6/5 :Walmart Mobil 1 Synthetic, 5 qt jug for $22.95
(1/6) > >>
Stewart G Griffin:
6/5:
Not sure if this is Nationwide, but my local W Mart has 5 quart jugs of Mobil 1 Synthetic for $22.95.
Not sure how long this will last either.
philo_beddoe:
Any idea the zddp value? Ppm?
Stewart G Griffin:
i'm afraid only the 15W-50 in mobil1  has the higher zddp levels.
Here is a list of high zddp oil levels:
http://www.corvetteforum.com/forums/c3-tech-performance/2484100-list-of-flat-tappet-oils.html
i was using Redline 10W-30 in the 305 and 350.
But with stock type valve spring pressures such as your crate 350, i don't think you have to worry about any of this zddp stuff.  But it's up to you.  And this is just my opinion.   i was using the Redline just to be safe.  Only costed a little more than conventional oil.
i don't have to worry about it anymore because i've joined the 21st century and now have roller lifters.   ;D
philo_beddoe:
Thanks, i dont like full synthetic, so i use valvoline max life 10w30 syn blend. It hs 800 ppm, then i add 4oz of the lucas additive, and that puts me right up there. Entire oil change plus ac delco filter comes to about $24. Lets see Amsoil or Joe Gibbs beat that!! And those royal purple nutheads are way over priced too!!
Stewart G Griffin:
Still on sale for $22.88  5 quarts.
https://www.youtube.com/watch?v=xILCJc2o_L8
Navigation
[0] Message Index
[#] Next page
Go to full version
