73-87 Chevy _ GMC Trucks > Electrical
1987 v10 dome light, horn not working
(1/1)
1987copper..v10:
1987 v10 dome light, horn not working. I've got hot going to dome and checks out fine, ran continuity with multimeter on ground, and get a decent reading, assuming i'm reading multimeter correctly. I thought ground(orange/white running to dome) may be corroded running through door threshold, so I cut it by fuse box, pushed on horn...and nothing, so i assume that ground is fine....Checked ground cluster behind instrument panel, detatched , inspected connections, everything looks fine, no corrosion.... checked door/dome light switch on driver side, looks perfect
bd:
Are you sure the dome lamp bulb is good? Orange is B+, white is switched ground. Reconnect the wires that you cut. Probe the orange wire using a test light clipped to ground to verify battery voltage. Then jump the white wire directly to a shiny clean bare metal ground. Does the dome lamp illuminate?
zieg85:
I had this same exact problem about 15 years ago on my 85. I think it was a fuse, caused by a bad ground. Check your fuses. Clean the ground on the left rear tail light. It didn't make sense that it was all connected.
1987copper..v10:
Bulb is good...orange is good, fuse is good, I think the ground is ony half good, or half bad, haven't worked on it yet... thanks for the replies, I'll update once I get a chance to work on it.
Navigation
[0] Message Index
Go to full version
