73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Ccm on August 08, 2017, 05:57:03 pm
Getting ready to start a project with my son..New to the world of engine swaps..but going for it...Does anyone know if the motor mounts for a 262 will work for the 305?
No the engine frame perches need to be changed as well. Stewart has done this recently, he will chime in, give it time, I just PM'd him...
This is right up my alley and i love this engine and swap. i'll get back to you in much more detail probably this weekend.
Until then, the short answer is that the mounts are different than the v-6 (they are reversed, although looking at it, the mounts SHOULD interchange, but let's do it properly for now with the v-8 mounts). Also, the frame perches are not the same. They may look the same, but on closer inspection, they are not. Photobucket has cancelled all my pictures, so again i'll try to provide examples this weekend.
Also, can i ask why you are going 305? Do you plan eventually going 350 and larger?
No..picked up the truck last October, engine has unknown amount of miles and was getting ready to do a tune up on it when I found this 305, also a 1986, but has 30,000 original mile on it..have video of the engine (305 ) running and supposedly it was only used on sunny days, and the owner took his driving test when he was 16 in it...they dropped a 350 bb it their truck. So wasn't really in the market for a upgrade but the price was right
First i want to ascertain why you want to swap and what are your goals?
Because an 86 305 only makes 5lbs more torque and 5hp more than the v-6. It is also 125 pounds heavier. Also, based on my and other's tests, the 305 will be down about 2 mpg from the v-6 on average.
So, you're getting very little performance advantage switching to a 305. i don't think you'd be able to tell the difference. Ok, the 305 does not vibrate at idle like the 6, but other than that....
i am not trying to talk you out of this because there are advantages:
If you switch to the 305, it's easy if you want to later switch to 350, 383 etc. BTW a 350 is NOT a big block. If you DID later want to switch to big block you MIGHT be also be able to use the small block v-8 mounts......?
Well this truck is going to be my sons first vehicle..soo..I really don't want it to be a rocket..just a dependable, good sound truck...the engine in it is shot..
And you think switching to v-8 would make it easy to be dependable----because of the universalness and popularity of the small block?
That's not a bad strategy, if that is your strategy? Fair enough.
i also want you keep in mind the possibility of getting a replacement 4.3---at about the same price as a crate v-8. (at least keep your v-6 parts in case you wanted to switch back someday).
Here we have a v-6 frame perch, driver's side:
(http://i.imgur.com/WrP9TLj.jpg)
Next, a v-8 frame perch, driver's side:
(http://i.imgur.com/pDobpyH.jpg)
Notice with the 6 perch, it is set back further towards the cab (because the v-6 is about 4.5" inches shorter than a v-8). AND if you look closely, one of the mounting points of the v-6 perch is on the SIDE of the framerail. Whereas the 8 perch bolts to the top of the frame rail and the other two bolts, bolt to the crossmember. (there are two bolts, one is hidden in the picture, but it's there)
So, you need v-8 frame perches and i'm thinking junkyard or maybe someone here can help. i would give you mine, but i want to keep mine just in case i want to switch back to 8 (not likely, but you never know).
Also, you will need to get v-8 specific mounts; i'm 99% sure that v-6 and v-8 mounts SHOULD interchange and SHOULD WORK, and if you look closely, i think you'll agree. But let's do it properly for now. (We can experiment later)
These do not have to be junkyard sourced. There are plenty of good aftermarket sources for that.
(http://i.imgur.com/g94essc.jpg)
Wow stew..I am digging this!! Great info..getting ready to pick up starter so I can do a compression test on the new motor..Had a question....This 305 has a 168 tooth flywheel..what would be the advantage of the 168 tooth FW over the 154 tooth? Is there any?...already figured out I need the offset starter for the 168, just wondered why it was on this motor?...
The 4.3's starter should work on the 305.
i'm not sure of any disadvantage or advantage of the 168 tooth flexplate vs. the 153 tooth. Perhaps someone can chime in?
Also, both the 4.3 and 305 should both use the 168 flexplate and should interchange.
Actually, if i could bug you for a sec.
Can you check for me if the starter on the 4.3 has a front brace like this:
http://nastyz28.com/threads/wtb-starter-brace.272580/
Hey stew!!..I know it’s been awhile, other projects have kept me busy but, the 305 got some upgrades by my son in his vocational auto class, and is ready to go in, he just got the perches mounted and the mounts on the perch, but the engine mount seems a little tight?
Good for you! Now, what do you mean by "too tight?"
So..I guess I need to get my wording right..the engine brackets..so we now have V8 mounting brackets en route to the door via the internet..now the question is, which mounting holes do we need to use on the perch for the engine mounts? it appears there are “upper” holes and “lower” holes for the mounts, and only 3 holes available for each engine mount?..soo 7 holes where the mount goes plus the 4 holes to secure it to the frame..
1) Which trans you got?
2) This may take until the weekend----i have to go in the garage to see my mounts.
3) Also, i would like to amend my thoughts concerning 4.3 vs. 305 and 305's in general:
i was looking at the torque curves of both engines (that's what i do......) in the gm heritage section. While the 305 "only" makes about 5hp and 5lbs torque more than the 4.3 AT PEAK, it does it a a lower rpm AND it's torque curve is much flatter than the 4.3's.
So the 305 not only makes more power, it does it at a lower rpm, and more consistently in the lower and higher rpm ranges; The 4.3's power curve looks more like a mountaintop, while the 305's is more like a plateau.
i think the 305 would likely make a better towing engine. On the other hand, with the right gears, the 4.3 could do ok for towing, but still wouldn't be as fast as the 305.
i think the takeaway here might be-----don't just look at peak numbers, look at the entire power curve.
4) The 305's radiator hoses "should" plug right into the 4.3's radiator. This radiator could probably be adequate for a while if you're not towing/hauling. Personally, i would not run this way for too long and would get a v-8 radiator, but that's just me.
5) The 305 might run even better because of the 4.3's torque converter. Which trans do you have?
i will try to get a picture of the mounts this weekend, but might take a while since they are somewhere in the garage........
Actually let's forget #4 +#5 for now----we are jumping ahead and should only do one step at a time.
(https://i.imgur.com/BV2mvaL.jpg)
It appears to be the top set of holes.
For these mounts, i have used nothing but SBC (305 and 350).
i am not sure why there are two sets of holes? Could it be transmission dependent? i have only had a TH-350.
