73-87 Chevy _ GMC Trucks > Projects Posts (NOT VEHICLES)
Coolant Overflow Tank Options.
<< < (3/4) > >>
Spool:
The specs said 1/4inch - think that's too small?
I purchased as that seemed to be the standard amongst others too.
And I got 10 feet of tubing so I can use some when I get to finishing my washer pump install.
JohnnyPopper:
I guess not, just used to seeing the Gunther stock tubing  ;)
1/4 is pry enough volume when you think about it.
Your washer tubing uses two sizes as I recall, having just replaced my wiper motor. Larger diameter between the pump and tank.
Spool:
The tank arrived.
I'm not that impressed. You get what you pay for.
Sure, it looks nice from a distance, but if you're looking to go to SEMA, this puke tank isn't it.
The mounts are specific for an aftermarket rad too.
So, I'll head to Home Depot and rig my own set up to avoid it being at an awkward angle.
I'll post pics when I finish.
JohnnyPopper:
Sorry to hear that, I hate it when the pics are deceiving. Look forward to your professional installation.   :)
Spool:
Tank is installed and it sells much better inside the engine bay as opposed to in your hands and inches from your face.
So, it's passable.
As I mentioned the mounting hardware was specific to an aftermarket rad, so I ended up buying these 1 inch corner braces from home depot.
I cut one of them in half, giving myself  (one) 1 inch brace and (one) 1/2 inch brace, because I noticed the front side of the engine bay is not 90degrees to the ground but more acute. So I used the 1/2 brace up top and the inch brace on the bottom allowing the tank to appear straight.
Also, by mounting it like this, the overflow outlet just so happens to clear the truck itself to spill straight to the ground.
I've attached pictures below. I'm pretty happy with it.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
