73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: harryk387 on November 19, 2019, 01:55:17 PM
I thought I had settled on a wheel/tire combo until some late night searching around these forums turned up that 275/60/15 on 15x8 wheel would cause issues with drop spindles up front and lower control arm rubbing. I really wanted to go with the 275/60/15 setup, but not if it's going to cause rubbing issues. I'm only planning on lowering my truck maximum 3" up front and 5" in the rear. Couple of questions about this.
a. Is the rubbing on the lower control arm because of the wheel diameter of 15"? Would going to a 16" wheel eliminate any rubbing issues?
b. If I kept the 15x8 wheel, would changing the backspace eliminate any issues?
Thanks for the help
You may need to reshape the LCA by grinding the lip near the ball joint area and or 1" wheel spacer adapters.
