73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: ladyharley on March 26, 2012, 11:39:25 AM
Since you guys are so great helping me in my other post... /leak.jpg[/img]] :-).......... I had the transmission fixed on the 1979 Chevy P/U. I believe it's a 350 Turbo. Everything was fine until there is a small leak. It's not at the pan. I'm inserting the pic of where the "drip" is. It a bolt at the corner. You can see the red drip about to drop. Is this an easy fix with a new bolt or is there a way to seal it with something? Everything else seems good. Picture is at http://i120.photobucket.com/albums/o184/ladyharley05
Thanks again..
Link no workie for me.
The link has an error. Nonetheless, the bolts in the image thread into blind (dry) holes. If it's not the pan gasket, fluid may be leaking from the front pump area (input seal/retaining bolt gaskets/pump o-ring) past the inspection cover then dripping off the bolt (the lowest point).
(http://i120.photobucket.com/albums/o184/ladyharley05/leak.jpg) how about this?
Is it maybe the lower trans cooler line?
The bolt? That's where it's dripping from that top little bolt
That bolt isn't leaking. The fluid is migrating from somewhere else.
I would check the dip stick tube gromet.
I would check all the bolts for the trans pan gasket, they have a tendency to loosen up. It appears the fluid is coming from the gasket area to the left of the said bolt, you can see red fluid along the seam where the gasket is.
It can be very difficult to diagnose a leak like that, especially if you are driving it and then notice it. transmission fluid could be coming from the front pump area and the act of driving it causes it to flow downwind. for example, you might see transmission fluid at the back of the transmission from a leak at the front of the transmission simply because airflow is causing it to trail back there.
I would clean the area very thoroughly and see if you can notice the leak without driving it anywhere.
Thanks for all the good suggestions. He put everything back together, so that's why I'm confused. I did notice the bolts to the pan loose when I got home and I tightened them, but that didn't seem to stop the leak. I think he used the gasket from before, which is only a few months old. I'm hoping that is it, I can change the pan gasket myself. But you're right ehjorten, I should try and wash the area (can't drive it like this) and see maybe where it's coming from.
Thanks!!!
so the pan gasket is reused? I never recycle a gasket. Once compressed, it's, um, compressed.
Yes it was reused :-\. He didn't buy a new one. So keeping my fingers crossed that is the problem and it will be resolved. I will go get a new one and replace it.
Thank you..
There are reuseable gaskets available, But all the aftermarket ones I have seen are a light blue color. The OEM Ford transmission pan ones are black.
