73-87 Chevy _ GMC Trucks > Engine/Drivetrain
Clutch & Flywheel setup
(1/1)
Da67goatman:
Background:  TBI 350 converted back to carb with HEI distributor along with np833 4 speed transmission from behind a 250ci straight six all going into a 62 c10. I'm in need of some assistance in picking the correct parts to mate the two.
I have the factory bellhousing with fork but would like to run a hydraulic master/slave setup for packaging.  It has been so long, I have forgotten about the multiple balancing and rear main options that the SBC has and have never dealt with a clutch that wasn't just a kit for that specific vehicle.  I know some of you die hard manual guys have all this stuff figured out so if you could recommend parts, I would be most grateful.
VileZambonie:
Look up parts using an 87 R10 350 for MY6 application.
Da67goatman:
Will that clutch require changing to a hydraulic throwout bearing?  Or can I use an external that pushes the factory clutch fork and throwout bearing?  The old style pressure plate only has 3 fingers vs the many of the newer style.
VileZambonie:
So I just swapped the clutch in my 75 Jimmy from the ole 3 finger to a Bellville spring type and boy is it easier and smoother. Are you familiar with the hydraulic clutch master and slave used on these trucks? They are external, not internal.
Da67goatman:
That factory external slave style is what I would like to use. I wasn't sure if the 87 r10 you referenced has a hydraulic throwout bearing or an external slave. Thanks a bunch for helping me get this sorted.  Is there a specific brand that seems to be better quality or brands that are trash quality?  I was leaning toward a LUK or exedy clutch kit, but I have no experience with either.  Same with a flywheel, any brands to stay away from?
Navigation
[0] Message Index
Go to full version
