73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: kfoz on August 12, 2009, 07:38:34 PM
Hello all!
what's the best oil pump to use in my stock '78 350??? Isn't there is a HIGH PRESSURE pump and a HIGH VOLUME pump? I may as well install a new pump while I am replacing the rear main seal and the pan gasket!
Please advise and thanks!
kfoz
I read somewhere that the stock type oil pump is more than adaquate for what I assume is a stock application. I am sure I will be corrected if I am mistaken.
+1. Stick with a stock volume pump. If you wish to do your oiling system a small favor, disassemble the pump and apply a nice radius to the internal exit passage. Also relieve and radius the inlet at the rear main cap.
yes, use a stock pump and pick up but use a steel sleeve driveshaft. Put a tack weld or jb weld around the pick up after you set it.
