and order the parts you need for your truck ! ! !
Steering box
Topic: Steering box (Read 4424 times)
whipper.snapper
Steering box
June 09, 2024, 02:43:54 pm »
Hey guys so I’m doing a frame off resto. Of my 1987 Chevy v10 and currently I am working on the steering box.
Before I took the steering box off of the frame I noticed it was leaking right there behind the rag joint. (See attached pics)
I am here to ask what would you guys suggest I do? Do I need to do a complete rebuild on it? Or should I just replace the seal/rag joint thing right where the leak seems to be.
Also I am having a hard time figuring out exactly which make and model of steering box I have. So if you guys have an idea of which one it is plz let me know.
If you know of the exact rebuild kit I need plz drop the part # of the kit.
Thank you guys in advance!!!
berserk
Re: Steering box
June 10, 2024, 03:45:51 am »
When my steering box started having issues I just went to O'Reilly's and bought a rebuilt unit. Is there any reason to keep this particular box? Rebuilding yourself would be way cheaper but do you have the knowledge to do that?
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
whipper.snapper
Re: Steering box
June 10, 2024, 08:43:41 am »
berserk, no I do not currently have the knowledge to rebuild this box myself. I have never rebuilt one. But very often I can find YouTube videos for help or someone on here can share some knowledge.
I didn’t want to buy a whole new or rebuilt unit if I can just replace some seals and O-rings and have it be good as new.
Shifty
I bleed Bowtie red...
Re: Steering box
June 10, 2024, 09:33:45 am »
Do not wander into your local parts store blindly....there are no more American-made boxes! Either rebuild yours, or if it's just leaking, replace that seal (Edelmann 8525, Omega 2779, Gates 351320). If you have to replace, I recommend Redhead Gears...
https://redheadsteeringgears.com/shop?year=1987&make=Chevrolet&model=V-10%20Pickup%20Truck%20(4WD
Don't let go of your original though, IMHO.
98 C2500 ext cab longbed
whipper.snapper
Steering box
June 10, 2024, 11:17:00 am »
Thanks for your opinion shifty, I was kinda thinking that same way.
From my pictures you can tell that mine is an original American-Made box?
Have you ever replaced that seal yourself? If so, Do I need any special tools to remove and replace it?
Last Edit: June 10, 2024, 11:19:26 am by whipper.snapper
Shifty
Re: Steering box
June 10, 2024, 11:29:26 am »
Your box is an original, though it may or may have not been re-built in the past. (we used to clean/re-spec/re-use cores, but now it's just cheaper to use chinesium castings).
I have changed that outermost seal, though it was a loooooooooooong time ago, IIRC, no special tools, except maybe a seal pick....
bd
Re: Steering box
June 10, 2024, 12:01:27 pm »
1987 Unit Repair Manual
, section 3B3. It's worthwhile to download the manual to your PC's hard drive.
whipper.snapper
Re: Steering box
June 11, 2024, 10:36:09 am »
Okay thanks guys, I’ve got the seal ordered and on the way. I reckon that will fix my issue.
Is it common for the Pittman arm shaft seal to leak? Should I go ahead and replace it while I’m at it?
Shifty
Re: Steering box
June 11, 2024, 10:44:56 am »
The pitman shaft is the one I've done the most...I don't know if I'd mess with it if it's not leaking though.
whipper.snapper
Re: Steering box
June 13, 2024, 07:44:21 am »
10-4, thanks for the help.
JohnnyPopper
Old Goof
Re: Steering box
June 17, 2024, 10:48:47 pm »
When those pitman seals go- they go!
Changed one on my K10 in the truck.
There are actually two seals.
If you've got it on the bench it's easier than being in the truck, although I would say, it wasn't that bad.
1980 C-10 under construction
whipper.snapper
Re: Steering box
June 18, 2024, 06:36:26 am »
I successfully changed the input shaft seal, gonna hold out on changing the Pittman arm, because it wasn’t leaking when I removed the box from the truck.
Steering box
