73-87 Chevy _ GMC Trucks > Electrical
Dash brake light
MY1978:
Hello, I have a new issue.
My dash brake light is stuck on even while in drive. I have depressed the emergency brake and released several times but it doesn't go out. I have checked the fluid level and it is fine. Every once in a GREAT while, it will go out. Today I ran a couple of errands and drove for over an hour and the light stayed on. Any suggestions/thoughts?
bd:
Is there any pattern as to when the brake warning lamp extinguishes? Unplug the tan/wht wire from the brake combination valve to see whether the brake warning lamp goes off and remains off.
MY1978:
No, no pattern. I assume the brake combination valve is under the hood? I will try that tomorrow.
**I found an explanation as to where it is. I will try that tomorrow**
bd:
The brake combination valve is a roughly 2.5" x 5" x 1" brass block that has 5 brake lines running to it and a single-pin switch that connects to the tan/wht wire for the brake warning lamp.
MY1978:
Thank you
Navigation
[0] Message Index
[#] Next page
Go to full version
