73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: 2tone4by on November 13, 2016, 09:58:18 PM
Anyone know the driveshaft length for the rear shaft. It is a shortbed with a th350 and 205 transfer case.....thanks
If you still need this I can measure mine. It's a 74 Short Bed with a th350/205, running to a 12 bolt.
Rob
Rob
Sent from my iPad using Tapatalk
Yes, that would be great....much thanks. If not too much trouble please give me the front shaft length as well.....thanks again
Well crap, after really thinking about it I don't think I can help.
Your reply reminded me my front shaft is no longer stock as I had a new one built to accommodate the 6" lift I have on the truck. The rear shaft is still stock. However, it is extended more than it would be at stock height.
Aside from pulling the lift and putting everything back to stock I unfortunately can't assist.
My apologies...
Rob.
