More thoughts....
Get an 88-94 column and an 84-91 column to experiment with.
The 88-94 GMT400 column wiper & dimmer switches might mechanically fit the 84-91 squarebody column... you aren't worried about compatibility with the existing 1984 cab harness. The only way to know is to try it.
You can probably liberate the column to firewall and firewall to wiper motor wiring as two subharnesses from your donor and remove / replace the 1984 wiring. Extracting Delphi Packard 56 terminals from the firewall bulkhead plug is fairly easy.
The 1993 wiring diagrams seem to use the same circuit numbers as 1984.
1995 wiring is in the emissions and service manuals. 95 is when GM discovered they could afford the next generation of embedded hardware. They did a pretty radical redesign of the electrical and again in 96 & again in 97. Airbags and other obnoxious hardware. I'd stick with 94 and down for that reason.
My GMT400 service manual project.
Parts books are only paper from 88-93 I dont have the ability to digitize microfiche...
http://67-72chevytrucks.com/vboard/showthread.php?t=700011Sent from my SM-P605V using Tapatalk
