Author Topic: Muncie M20 Shift Linkage  (Read 522 times)
Offline Ronno6
  • Elder Student
« on: April 15, 2018, 10:24:07 AM »
I am preparing to install a Muncie M20 into my 84 C10.
I pirchased a used M2o setup with Hurst Competition Plus shifter already mounted.
I am confused by the linkage.
Most pics I have seen orient all 3 shift levers upwards.
My setup has the 3/4 and reverse lever pointing up, but the 1/2 lever is pointing down.
I have seen 1 photo like that, but only 1.
Could this be correct, or is the previous owner playing a joke?
Also, my trany's date code does not match what I have seen online.
The # stamped into the case on the passenger side flange just ahead of the tailshaft housing is 7R26.
Maybe this means 1967 October 26 ???
I can find no casting date codes in the prescribed manner inside bisected circles.
So much to learn....
You can lead a man to water, but yoiu can't keep him from pissing in it.
Offline Rapid Roy
  • Euless, Texas
Re: Muncie M20 Shift Linkage
« Reply #1 on: April 15, 2018, 12:41:14 PM »
Welcome to the site
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
Offline Ronno6
  • Elder Student
« Reply #2 on: April 15, 2018, 03:18:04 PM »
Welcome to the site
Thanks. I 'preciate it....
Offline Peter S
« Reply #3 on: April 16, 2018, 06:12:38 AM »
Your tranny has a Hurst Super Shifter. The 3-4 gear linkage in incorrectly installed. The arm should be facing up so that the linkage rod is parallel with the 1-2 gear linkage rod.
« Last Edit: April 16, 2018, 06:14:27 AM by Peter S »
-Peter
1978 K10 stepside
Offline Ronno6
  • Elder Student
« Reply #4 on: April 16, 2018, 07:58:55 AM »
That is a pic I found on the web.
Mine has a Hurst Competition Plus shifter.
Offline Peter S
« Reply #5 on: April 16, 2018, 08:04:27 AM »
Regardless of which Hurst shifter you have, the 1-2 & 3-4 arms attached to the side cover face up.
-Peter
1978 K10 stepside
Offline Ronno6
  • Elder Student
« Reply #6 on: April 16, 2018, 08:55:51 AM »
That is what I thought.
Thanks.
I wonder why mine is not correct??
Maybe the previous owner wanted the stick in the forward position when in 4th gear??
