73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: pneuner750 on May 25, 2017, 07:59:30 PM
Trying to figure out how to remove the glove box latch! Bought a glove box, the plastic shell. Does anyone know how to remove the latch?
86 C 20, single cab, 350 4speed! Much appreciated
Sent from my SM-T813 using Tapatalk
You need to remove the lock cylinder before the latch. Read How to: Remove Glove Box Cylinder (http://forum.73-87chevytrucks.com/smforum/index.php?topic=15274.0) in our Technical Forum. The retaining nut hidden under the cylinder flange requires a special octagonal male driver. I expect the tool is long obsolete, so more than likely you will need to fabricate or adapt something to work.
pneuner750 ,your message box is full.
