73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Stewart G Griffin on October 27, 2017, 02:11:40 PM
Is the trans filter for a TH-350C different from a regular TH-350?
i thought the 350C has a notch cut out of it vs. a regular 350 which is square.
However, the AC Delco site lists the same filter as compatible with both transmissionses.
i don't want to drop the pan unless i'm sure i have the right filter. i have a 350C
250-350/c's are all the same. You're good
Yes, it turned out that the TH-350 and TH-350C use the exact same filter.
BTW on these trucks with TH-350's, the back two pan bolts are blocked by the trans crossmember, BUT you can get to them with a 1/4" drive socket----and some patience.
Check to see if your transmission mount is good and not sagging
trans mount is new and fine----an energy suspension mount.
