73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: JohnnyPopper on July 12, 2019, 12:58:46 PM
Hey Guys,
I bought a '88 C-30 and am replacing the th400. Got a used one (warrantied) from a yard I do a lot of business with, the tech pointed out that the T/C has 6 bolts.
Never seen one before, the original has 3.
Does anyone know the significance of why there are 6?
It came out of a '89 step van.
We opened up the pan and it was clean as a whistle.
Thanks for any guidance you can offer!
i've been seeing a few of these lately, because i have to do research on my own torque converter issues.....
i think 6-lugs are more heavier dutier/diesels.
What engine is in your c-30?
3 are SAE threads, 3 are Metric. Choose which set of 3 you need
Wow, that's all the difference? You mean my new T/C isn't special after all? :'(
When wrenching to get this pig out, I ran into bolts Sets, i.e. rear mount bolts, that were clearly metric, the rest being SAE.
The T/C bolts were/are 15mm.
The only thing I could figure was that the BIG 3 were so $ conscious of cost per vehicle that they went with lower cost hardware where ever they could.
Please feel free to disabuse me if there is another reason!
Carl (Zeig) all the threads are the same. Now what?
Choose the 3 that line up with your flex plate
i know on my motor swap the flex plate on the motor there was only 3 holes for the th400. someone modified it to fit the 700r4 (made the holes closer to the edge). when i mounted it up to the 4l80e i had to bring the holes back in
There are 6 points on the flexplate. Used all 6.
So there is no indication that this is a heavier duty T/C?
Came out of a delivery van.
OK. I learned something today. I have 2 TH400's and the flexplate in my 85 has 6 holes. I will have to check and see if mine is the same way. I am missing a speedometer drive gear before I put the new transmission back in...
i didnt know about the differences till after i bolted the cummins in place and no bolt holes lined up. PIA to pull it back out and modify the flexplate to work with the 4l80e
Yes, based on my research it is heavier duty and/or installed behind diesels. C-40,50 trucks, motorhomes etc.
2) if you look at the custom aftermarket converters that are put behind engines making 800+HP, they are 6 lugs.
That's all i know for now.
Wow Stuart, quite impressed! Thanks!
I admit I know very little about T/C's but wonder if this has a different 'stall' RPM?
I know that it can vary by design and application.
Hopefully this one isn't with a high RPM, however it is a C-30 with H/D rears suspension.
Any other Heavy Weight care to add to our knowledge base? TIA!
