73-87 Chevy _ GMC Trucks => Interior & Equipment => Heating, Ventilation & Air Conditioning (HVAC) => Topic started by: Ktc84shortbed on October 19, 2018, 01:41:36 PM
I have a 84 c10 non air and installing a 5.3 ls and has anyone ever tried to install the AC components as evaporator box and controls off say a 2000 or newer truck into a 84? I like the looks of just the dryer/accumalator on the fire wall and not the big box outside. Just a idea running through my head and using the ls 5.3 compressor lines and condenser would be practical install of customizing all that crap problem maybe is if there is enough room under dash to fit the newer unit and modifying for controls? I’m not to worried about wiring etc just a thought if anybody else has a wild imagination
Welcome
I had a friend put the AC components IN the factory AC box but you will never get the AC module behind that dash. It is HUGE. Using the lines isn't the issue if you are using the factory LS AC location you will need to modify the frame mount to work to give enough clearance on it.
