73-87 Chevy _ GMC Trucks > Seats and Restraints
Bench seat bolt sizes?
mizozuman2:
What are the bolt sizes that connect the bench seat to the floor of the cab?
Size, thread pitch, Length?
Thanks!
rich weyand:
Parts book says 3/8"-16 x 1-1/4", which jives with my memory from replacing them a couple years back. Note: I believe they are grade 5 or 8; I used grade 8 bolts to replace them. DO NOT USE LONGER BOLTS OR YOU CAN PENETRATE THE GAS TANK. I also used a 3/8"-16 tap to clean up the threads in the hard points in the floor before I put in the new bolts. Again, do not go deep enough with the tap to contact the fuel tank(s). I had a problem where some of the bolts had threads worn enough that they would not pull up tight. New bolts solved that.
Note: you did not mention the model year (I don't remember from the other thread we are chatting in). This info is from the 1973-1978 parts book.
mizozuman2:
--- Quote from: rich weyand on May 22, 2014, 12:32:48 AM ---Parts book says 3/8"-16 x 1-1/4", which jives with my memory from replacing them a couple years back. Note: I believe they are grade 5 or 8; I used grade 8 bolts to replace them. DO NOT USE LONGER BOLTS OR YOU CAN PENETRATE THE GAS TANK. I also used a 3/8"-16 tap to clean up the threads in the hard points in the floor before I put in the new bolts. Again, do not go deep enough with the tap to contact the fuel tank(s). I had a problem where some of the bolts had threads worn enough that they would not pull up tight. New bolts solved that.
--- End quote ---
I just need to make the truck my signature... LOL
Thanks. I'll check around some more. a guy gave me a link for an '86 Service manual. That should help me out quite a bit. Now, to find a printer..........
rich weyand:
That bolt probably did not change unless the seat belt mounts migrated to the seats. You can always pull one out and check it. If you pull one, pull out one of the front ones.
zieg85:
I can confirm that the bolts throughout the 73-87(91) is all the same
Navigation
[0] Message Index
[#] Next page
Go to full version
