73-87 Chevy _ GMC Trucks > Engine/Drivetrain
Ignition Control Module suggestions
fiddler:
I have a 1974 chevy C10 stepside. The engine is around a 1976 vintage 350. It has the hei ignition. I lost spark today. I had a load of wood on the truck and was heading 8 miles home when it died at a stop sign. Then it died momentarily on the freeway, but fired right back up. It kept kachunking up the last mile of hill getting to the house. When I got to the driveway it died 3 times while trying to position the truck to unload the wood. Now I have unloaded the wood and the ignition is totally non existent. I think my truck loves me. It waited to get home and the job done before it laid down.... That being said...I have a hot accel racing coil and wires on the rig just to ensure I got plenty of spark. I understand that the hot coil may be taking ignition modules. I don't race the truck and I was looking for reliability when installed that coil. Does anybody know 1) Do the hot coils in fact take out ignition control modules and 2) Is there a particular brand I should be looking for to get better reliability? So far the rest the components check good so I am pretty sure the ICM is gone again. This one lasted maybe 8000 miles.... I will go for parts tomorrow but may order them depending on response from you guys. I am also going to replace the coil with a standard stock level unit. Thanks much
Rapid Roy:
If it has the GM ACDelco HEI, replace with same parts. I had issues with the aftermarket modules until I replaced with the AC Delco parts.
bd:
The issue with high output ignition coils is the increased current demand placed on the switching module. There is nothing wrong with installing a high-output coil as long as you install a higher current capacity module at the same time. Consider using a Pertronix Flamethrower III module or MSD module with your Accel coil. Personally, I would upgrade the entire distributor with a billet MSD plus MSD digital box or leave the ignition completely stock.
fiddler:
So at this point the quick fix is to try the pertronix or msd module. In my heart I want to keep the high output coil. It just feels better to have hotter spark. The old girl starts and drives like a new truck most of the time so I want to not mess with what I have. If I lose the new module as well I will go back to stock at that time. Once more into the breech!! Thanks for your inputs. Always helps to share experience.
VileZambonie:
If you are running a high output coil, you also need to run the matching carbon button, cap and rotor. You will melt a hole right in that bad boy. My advice is run a stock, readily available to you unit. When you are ready, update the entire ignition system.
Navigation
[0] Message Index
[#] Next page
Go to full version
