73-87 Chevy _ GMC Trucks > Engine/Drivetrain
how to tell a cam?
(1/1)
aprice:
i know a guy through where i work that has two cam shafts for sale. one brand new with no documents, marking, etc for identifing it, and the other is barley used. i told him i'd make an offer next week for both. How do you measure the cam to figure what it is
roundedline:
Depending on what it is, the back of the camshaft at the distributor gear end will have a number and a marking on it indicating the PN or the grind.
If it is slightly used, does he have the lifters it was broken in with?
This is just my opinion, but I wouldn't give over $50 for a used set of cam and lifters, especially one you don't know the specs or history about. Chris Lucas
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
aprice:
i was thinking the same thing, $50-$75 for both cam shafts. he never said if it had the lifters or not
roundedline:
I wouldn't run new lifters on a used cam. They have a tendency to wipe lobes off or chew the lifter down. Chris Lucas
Project Su
Jimmy 2WD Project
aprice:
thanks, i wouldnt think to run new lifters with a used cam just cause things would be worn unevenly and a spell for engine disaster
Navigation
[0] Message Index
Go to full version
