73-87 Chevy _ GMC Trucks > 4 Wheel Drives
Transferring a 73 C body onto an 80 K frame
BradRuiz 83:
Will a 73 gmc 2 wheel drive body fit a 1980 k10 4x4 frame... anything helps thanks Brad...
BradRuiz 83:
Will a 73 longbed gmc body fit a 1980 k10 4x4 frame
JohnnyPopper:
Are the wheel base's the same? Long Wheel Base vs Short Wheel Base.
Obviously if one is a short bed and the other is long bed you will have to do some extra work.
If it's close and you're not sure, measure from the front spindle to the rear axle center on the 2x
and the center of the hubs to the rear axle on the 4x. Do they match?
BradRuiz 83:
Sorry... both trucks are longbed's
BradRuiz 83:
Did 1980 k10 4x4 come out with 10 bolt front axle...
Navigation
[0] Message Index
[#] Next page
Go to full version
