73-87 Chevy _ GMC Trucks > Electrical
Turn signal fuse power
83k10silveradooo:
There is power on the turn signal fuse and it jumps across to the flasher but the connector at the top of the flasher connector has no power on it to feed the turn signal switch
bd:
Replace the flasher.
83k10silveradooo:
ok maybe the flasher is defective, it's brand new but ain't nothing unheard of. I will try that thanks
bd:
Remove the old flasher, replace it with a wire jumper between the fusebox terminals and see whether the turn signals illuminate constantly when selected using the turn switch.
1980K20:
My first LED flasher was "heavy duty", meaning minimum 2A, max 20A. What was I thinking? These LED measure in the milliamp. I found a different flasher for really low amps and it works great now.
Sent from my SM-G965U using Tapatalk
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
