73-87 Chevy _ GMC Trucks > Engine/Drivetrain
90 Tbi swap into 85 K10 wiring help needed
bd:
You are correct. Custom Cruise III used a VSS speedometer with buffer that should supply signal to the ECM.
Custom Cruise III Manual
Oldsarge29:
I have the engine in and running. Everything seems to be working as it should right now. I still need to do a test drive. I have a purple wire that comes from the 3rd plug (white) near the ecm that is in pin L and I can’t figure out where it goes. This wire has a resistor inline and splits into 2 wires and both go back into the harness. The other problem is I’m working on the speed input for the ecm. My truck has the optical sensor in the speedometer and I found the speed buffer. I haven’t been able to figure out what wire I need to use for the input to the ecm. The ecm is out of a 90 2500. Any information on this world be greatly appreciated.
Oldsarge29:
Bump.
Anybody have any information on this??
bd:
The attached image should supply a key piece to the puzzle.
Navigation
[0] Message Index
[*] Previous page
Go to full version
