Technical Forum (Read Only) > Drivetrain
Universal joint conversion part numbers
(1/1)
Irish_Alley:
This is for those that put a 14 bolt under their truck and need to know what universal joint to go with, the 1350 is the 14 bolt universal.
just verify what universal you have on your rig now and match it up to the conversion universal and you should be good
O.E.M. Part Numbers
S44 Dimension : 1.125" x 1.125" Brg. Dia. 2.556" Between Grooves 1 or 2 piece drive shaft (inside lock rings)
1310 Dimension : 1.063" x 1.063" Brg. Dia. 3.219" Overall Width 1 piece drive shaft (outside lock rings)
1330 Dimension : 1.063" x 1.063" Brg. Dia. 3.622" Overall Width 2 piece drive shaft (outside lock rings)
1350 Dimension : 1.188" x 1.188" Brg. Dia. 3.622" Overall Width 2 piece drive shaft (outside lock rings)
NAPA Part Numbers
S44 = NPJ P534G Dimension : 1.13" x 1.13" Brg. Dia. x 2.37" x 2.37" Between Grooves
1310 = NPJ P369 Dimension : 1.06" x 1.06" Brg. Dia. x 3.22" x 3.22" Overall Width
1330 = NPJ P354 Dimension : 1.06" x 1.06" Brg. Dia. x 3.62" x 3.62" Overall Width
1350 = NPJ P331 Dimension : 1.19" x 1.19" Brg. Dia. x 3.62" x 3.62" Overall Width
NAPA Conversion Joint Part Numbers
NPJ P534G to NPJ P331= NPJ P447 Dimension : 1.12" x 1.19" Brg. Dia. x 3.62" x 2.36" Width Overall / Between Grooves
NPJ P369 to NPJ P331= NPJ P348 Dimension : 1.06" x 1.19" Brg. Dia. x 3.62" x 3.21" Overall Width
NPJ P354 to NPJ P331= NPJ P448 Dimension : 1.06" x 1.19" Brg. Dia. x 3.62" x 3.62" Overall Width
NPJ P534 to NPJ P369= PUJ 372 Dimension : 1.125" x 1.063" Brg. Dia. x 3.220" x 2.56" Width Overall / Between Grooves
NPJ P534 to NPJ P354= PUJ 355 Dimension : 1.125" x 1.063" Brg. Dia. x 3.622" x 2.56" Width Overall / Between Grooves
NPJ P369 to NPJ P534= PUJ 353 Dimension : 1.063" x 1.063" Brg. Dia. x 3.620" x 3.22" Overall Width
Oreilly's Universal Joints
S44 = 534G Dimension : 1.125" x 1.125" Brg. Dia. x 2.557" x 2.557" Between Grooves
1310 = 369 Dimension : 1.063" x 1.063" Brg. Dia. x 3.218" x 3.218" Overall Width
1330 = 354 Dimension : 1.063" x 1.063" Brg. Dia. x 3.620" x 3.620" Overall Width
1350 = 331c Dimension : 1.188" x 1.188" Brg. Dia. x 3.625" x 3.625" Overall Width
Oreilly's Conversion Joint Part Numbers
534G to 331c = 447 Dimension : 1.125" x 1.188" Brg. Dia. x 3.62" x 2.56" Width Overall / Between Grooves
369 to 331c = 348 Dimension : 1.06" x 1.188" Brg. Dia. x 3.62" x 3.22" Overall Width
354 to 331c = 448 Dimension : 1.063" x 1.188" Brg. Dia. x 3.62" x 3.62" Overall Width
534G to 369 = 372 Dimension : 1.125" x 1.063" Brg. Dia. x 3.220" x 2.56" Width Overall / Between Grooves
534g to 354 = 355 Dimension : 1.125" x 1.063" Brg. Dia. x 3.622" x 2.56" Width Overall / Between Grooves
369 to 354 = 353 Dimension : 1.063" x 1.063" Brg. Dia. x 3.620" x 3.22" Overall Width
Advance Auto Parts Universal Joint Part Number
S44 = 2-3011BF Dimension : 1.125" x 1.125" Brg. Dia. x 2.556" x 2.556" Between Grooves
1310 = 1-0153BF Dimension : 1.063" x 1.063" Brg. Dia. x 3.219" x 3.219" Overall Width
1330 = 2-4800BF Dimension : 1.063" x 1.063" Brg. Dia. x 3.622" x 3.622" Overall Width
1350 = 2-0053BF Dimension : 1.188" x 1.188" Brg. Dia. x 3.622" x 3.622" Overall Width
Advance Auto Parts Conversion joint Part Numbers
not available
2-3011BF to 2-0053BF = 2-1153BF
1-0153BF to 2-0053BF = 3-3140BF
2-4800BF to 2-0053BF = 2-3050BF
Autozone Part Numbers
S44 = 2-3011DL Dimension : 1.125" x 1.125" Brg. Dia. x 2.559" x 2.567" Between Grooves
1310 = 1-0153DL Dimension : 1.062" x 1.062" Brg. Dia. x 3.21" x 3.218" Overall Width
1330 = 2-4800DL Dimension : 1.062" x 1.062" Brg. Dia. x 3.621" x 3.621" Overall Width
1350 = 2-0053DL Dimension : 1.187" x 1.187" Brg. Dia. x 3.62" x 3.621" Overall Width
Autozone Conversion Joint Part Numbers
not available
2-3011DL to 2-0053DL = 2-1153DL
1-0153DL to 2-0053DL = 3-3140DL
2-4800DL to 2-0053DL = 2-3050DL
Neapco Universal Joint Part Number
S44 = Neapco:2-3011 1.125" x 1.125" Brg. Dia. x 2.556" x 2.556" Between Grooves
1310 = Neapco:1-0153 Dimension : 1.063" x 1.063" Brg. Dia. x 3.219" x 3.219" Overall Width
1330 = Neapco:2-4800 Dimension : 1.063" x 1.063" Brg. Dia. x 3.622" x 3.622" Overall Width
1350 = Neapco:2-0053 Dimension : 1.188" x 1.188" Brg. Dia. x 3.622" x 3.622" Overall Width
D44 joints = Neapco:1-0297 Dimension : 1.188" x 1.188" Brg. Dia. x 2.188" x 2.188" Overall Width
Neapco Conversion Joints Part Numbers
2-3011 to 2-0053 = Neapco:2-1153
1-0153 to 2-0053 = Neapco:3-3140
2-4800 to 2-0053 = Neapco:2-3050
2-3011 to 1-0153 = Neapco:3-3130 Dimension : 1.125" x 1.063" Brg. Dia. x 3.219" x 2.556" Width Overall / Between Grooves
2-3011 to 2-4800 = Neapco:2-1569 Dimension : 1.125" x 1.063" Brg. Dia. x 3.622" x 2.556" Width Overall / Between Grooves
1-0153 to 2-4800 = Neapco:1-0134 Dimension : 1.063" x 1.063" Brg. Dia. x 3.622" x 3.219" Overall Width
GMB Universal Joint Part Number
S44 = GMB:210-3105
1310 = GMB:214-0153
1330 = GMB:210-1203
1350 = GMB:210-0086
D44 joints = GMB:210-0297
GMB Conversion Universal Joints
214-0153 to 210-0086 = GMB:240-0358
210-3105 to 214-0153 = GMB:240-0356
210-3105 to 210-1203 = GMB:210-3009
214-0153 to 210-1203 = GMB:215-0134
Spicer Universal Joint Part Numbers
S44 = Spicer:5-3147x
1310 = Spicer:5-153x,5-467x
1330 = Spicer:5-229x,5-230x,5-273x
1350 = Spicer:5-447x
D44 joints = Spicer:5-297x
Spicer Conversion joint Part Number
5-153x to 5-447x = Spicer:5-460X
5-3147x to 5-153x = Spicer:5-3022x
5-3147x to 5-153x = Spicer:5-212x
5-153x to 5-229x = Spicer:5-134x,5-344x
Front drive shaft Double Cardan (CV) Ball Seat Repair Kit
NAPA part number UJ 612
Summitracing MOG 612
Amazon Precision 612
EBAY ACDELCO PRO 45U0701
Rockauto MOG 612
if you google 612 cv ball seat you should come up a good part
also part number 606 will work.
Advance Auto 606
Oreilly auto 606
Amazon
Napa 606
Navigation
[0] Message Index
Go to full version
