So I've been on what seems like a never ending project to replace the spindle/arms/springs. Installed the belltech (3in drop for 1in rotor), bolted on just fine, no issue - the issue is with the caliper not fitting like it should be. I have aftermarket rotors that fit just fine on the stock spindle. I've read that sometimes you have to grind part of the spindle for it to fit, anybody have this issue? Is so, where exactly do you grind?
Thanks in advance!
