Author Topic: Crew Cab VIN Coming Back As 4x2  (Read 2858 times)
Offline jpearson311
« on: May 30, 2023, 03:56:39 PM »
Hi all.  I'm looking at an '88 crew cab (square body) and in the pictures, it is clearly a 4x4, but the VIN is is coming back as a 4x2.  Could this be because the VIN digit that specifies the drive is a "R" rather than a C or K?  Thanks!
Offline JohnnyPopper
  • Old Goof
Re: Crew Cab VIN Coming Back As 4x2
« Reply #1 on: May 30, 2023, 05:48:27 PM »
Could have been converted, just saw one on Bat that was listed as a C10 but clearly was 4x4.
1980 C-10 under construction
Offline jpearson311
« Reply #2 on: May 30, 2023, 06:37:35 PM »
Ok, but that's C vs K. I believe they're different for crew cabs. Especially for an '88.
Offline bd
« Reply #3 on: May 30, 2023, 07:38:23 PM »
With regard to 1988 light-duty GM trucks, R/V refers to the older square body design, whereas C/K refers to the subsequent (newer) body style.
R = RWD / 2WD
V = 4WD
Offline jpearson311
« Reply #4 on: May 30, 2023, 07:42:05 PM »
4WD became V in 87. Prior to that it was K. So you're saying that in 87 the C became R?
  • Old Goof
« Reply #5 on: May 30, 2023, 08:13:11 PM »
R = RWD / 2WD
V = 4WD
Gotcha bd! Doesn't happen often but it made me grin!  8)
Offline bd
« Reply #6 on: May 30, 2023, 10:57:05 PM »
Yes, but C/K became R/V only as the designations applied to the older square body design.  This is how the lizard grew into an alligator...
Traditionally, GM used the C and K designations for their 2WD and 4WD trucks, respectively.  In 1987, GM introduced a newer, more aerodynamic body style and wanted to continue marketing the C/K tradition.  BUT, it wasn't a smooth transition.  Instead, GM continued to produce the older square body design through 1991, overlapping the initial production of the newer C/K body style in 1988.  That presented an interesting (and with even a little forethought, avoidable) marketing problem.  SO, in GM's infinite wisdom, it rebranded the 1987 square body C/K designation to R/V in a bungled attempt to prevent public confusion with the newly released C/K truck line.  As a result, 36 years hence, people are still confused.   ::)
Offline jpearson311
« Reply #7 on: May 30, 2023, 11:07:36 PM »
So the truck that I'm looking at is an '88, but it's a crew cab square body. The only squares that I know of after 87 are the K5s.
Offline bd
« Reply #8 on: May 31, 2023, 07:55:49 AM »
...and Suburbans and Crews, I believe.
Offline MIKE S
  • Member
« Reply #9 on: May 31, 2023, 08:57:55 AM »
Also 2dr cab and chassis as we had many on our farm.
Offline bd
« Reply #10 on: May 31, 2023, 09:25:56 AM »
Yeah, I forgot about the CACs.  It certainly was a clunky rollout and transition.  It's as though GM had hesitation in committing.
Offline MIKE S
  • Member
« Reply #11 on: May 31, 2023, 11:23:56 AM »
I remember when I used to service these back when they weren't very old. The R/V vs C/K designation was very confusing for the parts stores when getting parts. Say you needed a water pump for your 1988 Chevy 1 ton cab and chassis. If it was a square body it was an R series. If the parts guy at the local parts store looked up the part and gave you a pump for a C series you would have gotten a reverse rotation pump that physically looked identical but it would have not worked and overheated. I had to "school" most of my part suppliers as they had no idea what an R/V series was.
Offline bd
« Reply #12 on: May 31, 2023, 01:13:26 PM »
LOL.  Unfortunately, that still occurs.
Offline Shifty
  • I bleed Bowtie red...
« Reply #13 on: May 31, 2023, 01:20:08 PM »
Easy as pie if you're a Square-Body counterman... :D
98 C2500 ext cab longbed
