73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: Sprinkler-Man on June 07, 2019, 07:18:24 PM
I can’t get my fill plug out but there is a breather vent on the top I can access and fill from. I have been reading to go with 2 quarts but wanted to confirm with the forum.
Good luck with that. Extract the fill plug and save yourself some aggravation. Is it stripped, what's the problem?
Yes it’s striped. Unfortunately, I don’t have a welder to weld a bolt to it. I pulled off the breather cap and can blow down through the vent, but this was with the differential cover off. Why do you see a problem?
have to get vile of one of those to confirm but one thing i know you might be able to do is put the right amount of oil in a ziplock and toss it in the differential.
What??
i remember seeing on tv a few years ago someone rebuilding a read end. when they filled it they just filled a zip lock full of gear oil and tossed it in. they said the zip lock would break down and it will be ok. but i dont recall what style differential it had. so if they worked on something like a Detroit locker, i dont know if you can do the same for lets say a gov locker
I pulled the vent and put in two quarts. Took me about 15min to do. Now I can take it to a shop to get a bolt welded into the plug to get it out and replace it.
What??
LMAO
Use this: http://www.ctatools.com/index.php?route=product/product&path=59&product_id=150
Why would anybody entertain, let alone recommend, using something that belongs in the county dump to put "clean oil" in a differential? But then, if it was on TV or UBoob, it must be true....
its true lol thats kind of why i wanted one of you two to confirm what i saw. glad we got that all cleared up now, but for real i remember them tossing it into the rear then sealing it up and saying something like the gears will break it down in no time
OMG
Was it from the '70s or some other mislead era? HeeHaw?
it was one of those shows on power block or something like that, believe back around 2010.
Well, plastic is a byproduct of oil, so in theory it will return to 'natural state'...
that was my thinking also and why it made sense. but i wasnt sure if somehow it would mess up the clutches on some model rear ends
Give it a rest. Nothing about it makes sense. It is poor practice!
