73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Chuck Step-a-side on March 10, 2018, 09:02:28 AM
My 1984 Chevy Silverado Stepside was converted from a 305 TBI to 350 4 bbl. before it was purchased by me. The question I have concerning the engine swap has to do with the fuel lines?
On the original 305 TBI with dual saddle tanks; there are the 3/8” fuel line, the 1/8” return fuel line and the 1/8” vapor lines.
What is to be done with the 1/8” return and vapor fuel line when converting to 350 with mechanical fuel pump and Edelbrock 4 bbl?
Should the return lines be blocked off and/or the mechanical fuel pump converted to one without the return outlet or leave as-is?
Is there a fuel line route diagram for 1984 truck with dual tanks?
As always, thank you for your help, Chuck.
Your 84 had a carb. 87 was the first year TBI was available. Those lines should be connected. IIRC one goes to the fuel pump, the other goes to the charcoal canister. I'm not positive about that. There should be a diagram on the radiator support. Otherwise look in the tech section or hopefully someone else knows and tells you.
The 1/8 is actually 1/4 return from the fuel pump. The 3rd line is 5/16 which is the canister as mentioned.
The return is not an issue if you have no vapor lock issues.
Vapor lock issues with my 74K5 began with the up to 10% ethanol fuel. I do not have the 1/4 return so I used the 5/16 canister line for my return.
No reason not to have all hooked up as original
3/8" fuel feed line, 5/16" return line, 1/4" vapor recovery line. The mechanical fuel pump is a 2 line fuel pump with the 5/16" return line. 1/4" vapor recovery goes to the charcoal canister.
Erik, the 1/4" line should be fuel return from the pump to the tank. The 5/16" line is fuel tank vent to the vapor canister.
Chuck, as Blazer74 pointed out, there are no 1/8" fuel system related lines. If your truck was converted from carburetion to TBI, and then back to carburetion, take a close look at the line configuration in case it has been altered.
BD...didn't realize they swapped the 1/4" and 5/16" on a carb'ed vehicle. 1/4" is vapor line in FI truck.
To my knowledge the standard was:
carbureted 3/8" supply, 5/16" vapor, 1/4" return
EFI 3/8" supply, 5/16" return, 1/4" vapor
I'm sure there are variables for different configurations.
