Author Topic: shredded fuel pump  (Read 4142 times)
Offline bd
Re: shredded fuel pump
« Reply #15 on: April 25, 2019, 10:57:35 PM »
A torque wrench is unnecessary.  Have you closely inspected the flare and inverted flare for damage, checked for cracks/splits in the walls and folds of the tube?  The tube should be double flared.  Is it?  If all of the above checks out okay, you probably need to tighten the fitting some more.
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: April 26, 2019, 03:39:43 PM »
Put your back into it Lad!
1980 C-10 under construction
Offline BillWill
« Reply #17 on: April 28, 2019, 03:22:11 PM »
Okay, so previously I never took the entire hard line out of the truck but I figured with my issues I might as well just to be 100% sure that I am getting it completely cleaned and able to test threads with something else.
What I found  was that there was a nick in the threads but I honestly don't think it was going in far enough to be the root cause.  Regardless I took it to O'Reilly's and ask them to fix the threads (I don't own a tap and die set) and today after getting it put back together I no longer have a gas leak.
Thanks for the help guys.. I"m truly just learning as I go here..
1986 chevy K10 Scottsdale
305 w/700r w/np208 w/AC
3.73 gears 10 bolt rear
3" lift on 33's
  • Old Goof
« Reply #18 on: April 29, 2019, 04:01:16 PM »
Nice detective work! Glad you're back on the road!
That was one beat up fitting... how did you gash that so badly?
Offline Manswame
  • '82 k10 with 305 stock
« Reply #19 on: May 01, 2019, 12:58:53 AM »
For the love of God what are these fitting called.
Sorry didnt mean to hijack your thread.
Sent from my SAMSUNG-SM-G891A using Tapatalk
1982 K10 with 305 STOCK
  • Old Goof
« Reply #20 on: May 01, 2019, 03:29:39 PM »
From BD:
Inspect the tube and fitting flare faces for distortion or nicks and make sure the tube nut is square when started into the fuel pump.
We're all a little wiser now.... 8)
Offline bd
« Reply #21 on: May 01, 2019, 07:51:24 PM »
They are called tubing nuts but are also referred to as line nuts, flare nuts, tube nuts [sic].  No puns!   ::) :P :-X
