73-87 Chevy _ GMC Trucks > Interior & Equipment
Need rear speaker mounts
Shifty:
Over at the 67-72 Chevy Truck forum...you know, the light side.... ;)
Geezer77GMC:
These brackets worked very well for me using 6x9's.
http://www.73-87.com/Parts/7387SpeakerBrackets/73-87%20Cab%20Corner%20Speaker%20Brackets.htm
Shifty:
That's them Geez, I wasn't certain of the ethics of the link. :D
Geezer77GMC:
I had my brackets covered in the same materail as the seat & door panels. I added a plywood spacer between the bracket and speaker ring for large magnet clearance. The brackets fit very well and are solid.
Ben_Olddermin:
--- Quote from: zieg85 on August 16, 2022, 07:14:54 AM ---are you looking for the stock steel factory mounts for the 4x10?
--- End quote ---
No I already have those. Trouble is they won't fit a modern 4x10. Which I also have.
The 4x10 magnet is too big. So I thought maybe the 6x9 bracket would be better because the hole would be moved. But seeing Geezer's plywood idea makes me want to try that before I order. I could just make some little spacers that would move the 4x10 speaker out so the magnet wouldn't contact the cab. But it's gonna be way out. Maybe 4x10's are just outdated and should go the way of the dinosaur.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
