73-87 Chevy _ GMC Trucks > 4 Wheel Drives
Spindle damage/steering knuckle
A robs 23:
While removing my spindle for ball joint replacement. I accidentally damaged near the bearing surface. Is this too much damage to re use?
Also, any tips on removing this steering knuckle that is so corroded i feel it may be welded onto the axel (sarcasm).
Thanks!!
VileZambonie:
File it and you will be okay. Looks like you mashed the stud with a hammer for the steering arm. If you are trying to remove it, you need to remove the cone washers first.
A robs 23:
Im trying to remove the steering knuckle. I wont be upset if i cant get the steering arm off
VileZambonie:
Guess I looked too quickly at your picture. Hit the pickle fork with a BFH or use an air hammer. You can also strike it on the X a few times
A robs 23:
Thanks!
Navigation
[0] Message Index
[#] Next page
Go to full version
