what years did the 1.25 rotor come on the 2wd half ton or is it more complex then that
the reason I ask is that many moons ago I ordered a set of sindles through godfathers and they told me the 79 I had the 1.25 rotors without me measuring and they were right so what years or models came with the 1.25 rotor
The got lucky. It was optional on all 1/2T pickups.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
I believe heavy halfs and diesel trucks had them.
Toys are my game
Sorry, I guess that was a short answer... RSBAD454 is correct. Diesels and Trucks with the HD (Heavy Half) suspension had the 1.25 rotors also. Along with every Blazer/Jimmy and Suburban.
Project Su
Jimmy 2WD Project
acording to the measuring tape at advanced the 1979 replacement rotors for a regular 1/2 ton 2wd is 1.25 inches no hd spec or anything but my search must go on for a more specific answer
i dont no if it will help,but i have a 78 2wd jimmy w/ 1.25 roters,plus my 85 c/10,& had a 77 h.half lb., now i just tore down 84 sb for parts & its got 1.00 what is differant then the others its manuel brakes & steering,6cyl.-3 on-the-tree maybe thats the key...roll low..drag hard ..toby
The specific answer is if you have HD suspension, you have HD brakes. ALL Jimmy/Blazer, Suburbans and Heavy Half pickups have HD brakes. All trucks with option J55 also have the HD brakes.
Project Su
Jimmy 2WD Project
