73-87 Chevy _ GMC Trucks > Fuel Systems and Drivability
Fuel Cell Install in the Bed
(1/2) > >>
Chevynut73:
After taking the '73 from a long bed to a short bed, i had to remove the original fuel tank and don't really want to install a short bed 16 gal tank in the frame so would like to install a fuel cell in the bed.
My question is  -  Do i need to/have to hook up the RETURN LINE to the canister under the hood ?
Thanks
Captkaos:
Your fuel pump will have a return line so yes.  To get rid of that you would have to run a electric pump/regulator in the tank set to the ideal 5-7lbs that your carb wants.
This is assuming you are just changing tanks.
VileZambonie:
Why would you want a fuel cell in the bed? Just replace the tank
Chevynut73:
Thanks for the info, i will go ahead and run the return line.
VZ - your answer is in my post, thanks.
VileZambonie:
--- Quote from: Chevynut73 on January 16, 2024, 12:38:21 PM ---Thanks for the info, i will go ahead and run the return line.
--- End quote ---
Because you didn't really want to. I got that much ;D
Navigation
[0] Message Index
[#] Next page
Go to full version
