Author Topic: Oil sensor extension pipe  (Read 1672 times)
Offline bigblockchevelleman
« on: April 11, 2021, 07:18:55 PM »
Currently installing the engine back in the Truck . The problem is that after the extension tube is installed I'm  not able to get the sensor in because it's up against the block almost like if the tube was a 1/4 -1/2 longer it would be ok or if maybe the tube threads were straight or different angle and help or idea's  Thank you  Steve
Re: Oil sensor extension pipe
« Reply #1 on: April 11, 2021, 07:44:04 PM »
The sensor is right above the oil filter not the one behind the intake manifold because it's a 1987 r10 350 and there's one there I think for the fuel pumps to know there's oil pressure
Online bd
« Reply #2 on: April 11, 2021, 11:43:05 PM »
Post a pic of the trouble you are having.
« Reply #3 on: April 12, 2021, 01:06:00 AM »
Been trying to post a picture and I've got to figure out how to reduce because it says file to large
« Reply #4 on: April 12, 2021, 01:08:28 AM »
Maybe it will post
« Reply #5 on: April 12, 2021, 06:19:09 AM »
If you put a different manifold on, then you may need a bushing. Go to the hardware store and get an assortment of bushings and adapters. Get some pipe thread sealant as well.
« Reply #6 on: April 12, 2021, 09:07:58 AM »
Thought about that but the size of the inside is small  afraid if it's larger might cause a worse leak
« Reply #7 on: April 12, 2021, 02:00:17 PM »
Offline MIKE S
  • Member
« Reply #8 on: April 12, 2021, 09:02:22 PM »
Maybe you don’t have the extension orientation right. I just looked at my 87 and the sensor is angled slightly back towards the transmission from the straight up position. And yes it is very close to the block but it does fit.
