Author Topic: Transmission purchase question  (Read 2112 times)
Offline Chuck Step-a-side
« on: May 18, 2019, 11:35:06 AM »
I'm swapping out my 350 engine on my 1984 Silverado Stepside and thinking about replacing the Turbo 350 transmission.
So my question is - would you purchase a re-manufactured transmission from online vendor or purchase a rebuild from a local transmission guy? The local guy offers all the performances upgrade and 1 year warranty and unlimited miles.
Re: Transmission purchase question
« Reply #1 on: May 18, 2019, 01:12:38 PM »
are you upgrading to a 700r4? i would go local as long as they have a good reputation
« Reply #2 on: May 18, 2019, 06:05:12 PM »
Yes, I think that upgrading to the 700R4 would a great choice. I know I need to shorten the drive shaft, but what I need to make the overdrive operational is beyond me. There's a lot of info on the internet, but there are not clear on the procedures. Any help would be great.
Offline Stewart G Griffin
« Reply #3 on: May 20, 2019, 02:19:50 PM »
i went with:
http://www.atiracing.com/
It has been working great and i would recommend them to anyone.
They happen to be local to me, but they do ship anywhere.
2) IF the local builder is good , then i  wouldn't have a problem going with them.
3) the 2004R is likely an easier swap if you already have a TH-350.
« Reply #4 on: May 20, 2019, 04:06:33 PM »
I went from a TH350C to a 700R4 in a 1985 C10 a couple of years ago and all I had to do is move the cross member back and drill a couple of new holes in the frame.  The transmissions were very close to the same length and the driveshaft fit fine.
« Last Edit: May 20, 2019, 08:52:04 PM by zieg85 »
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: May 20, 2019, 05:13:03 PM »
https://www.summitracing.com/parts/prf-60109/overview/
You will need something like this. There are a couple of brands that I have seen through the years.
Don't know if the 'store' carries products like this.
If they do, I expect to be yelled at...
1980 C-10 under construction
« Reply #6 on: May 21, 2019, 02:54:11 PM »
you reused the same driveshaft from the th350?
« Reply #7 on: May 21, 2019, 03:01:00 PM »
Yes I did, the transmissions were less than 1/2" difference in length if I remember.  It was one of the easiest swaps I have ever done.  Guy I sold it to still has it
« Reply #8 on: May 21, 2019, 08:58:13 PM »
nice. have to try and remember that. do you remember what length tail housing the th350 had?
« Reply #9 on: May 21, 2019, 09:06:40 PM »
had to be the 9" tail shaft
  • Old Goof
« Reply #10 on: May 22, 2019, 03:34:28 PM »
Good catch Zeig, thanks for the pic!
I haven't seen a Powertoilet for years!
