73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Cdog_1996 on January 24, 2022, 08:04:51 PM
Title: 1983 Chevy k10 With 454 Starter issue
Post by: Cdog_1996 on January 24, 2022, 08:04:51 PM
Need help!  I have a 454 out of a 78 suburban in my 83 k10, has started and ran before but my starter is very far out from the flex plate, the Bendix might catch 1/16 of an inch of the flex plate, turns slow, sometimes it doesn't do anything and virtually impossible to get it to crank consistently.  Makes a terrible screeching sound, I've tried a stock style and a mini starter both with the same issue, I can't find a solution for this problem
Title: Re: 1983 Chevy k10 With 454 Starter issue
Post by: wz7u on January 24, 2022, 08:14:55 PM
Wrong flex plate?
Post by: Cdog_1996 on January 24, 2022, 08:19:25 PM
I don't think so, it was attached to a th400 and then pulled I installed it to a built th350, seems original I don't see why or how the flex plate would be wrong and it matches the pads on converter
Post by: JohnnyPopper on January 24, 2022, 09:11:18 PM
Try some shims.
Post by: Shifty on January 25, 2022, 07:58:40 AM
Is the bendix fully extending (and at least 12v to the starter)?
Post by: JohnnyPopper on January 25, 2022, 01:07:51 PM
Is it possible that it's in backward?
Post by: Cdog_1996 on January 25, 2022, 06:10:35 PM
We'll boys it looks like my flex plate is on backwards, I thought the motor was never messed with but I was wrong
Post by: JohnnyPopper on January 25, 2022, 11:20:28 PM
It happens... ::)
Post by: Shifty on January 27, 2022, 08:32:15 AM
Nice spot JohhnyP!  ;)
Post by: JohnnyPopper on January 27, 2022, 12:35:54 PM
Thanks Shifty!
My 383 is still on the stand, and when I looked at it I could see how that would really 'shift' things!
I'm sure his TC was pulled out as well.
