Author Topic: Strange block casting #  (Read 2101 times)
Offline Ronno6
  • Elder Student
« on: October 19, 2018, 03:29:16 PM »
This motor is from an '93 GMC 1500 pickup.
It is a 5.7 TBI and has swirl part heads
Closest to a block casting # I could find is:  2233886
It is on the passenger side flange bell housing flange.
I cannot find anything close to that anywhere on the WWW.
Anybody seen that before?
You can lead a man to water, but yoiu can't keep him from pissing in it.
Re: Strange block casting #
« Reply #1 on: October 21, 2018, 12:41:36 PM »
Is the motor in the vehicle?  Never heard of that number sequence for a SBC
Offline Ronno6
  • Elder Student
« Reply #2 on: October 21, 2018, 05:24:14 PM »
OK. Now that I own it and can actually SEE the number, it is 10243880
It came out of a 1993 1500 GMC truck, but from what I have read,some info says that engine is newer than that. 95 - 96
(Some says 87-00, so, who knows??)
I dunno,,, so much conflicting info.
There is what I believe to be a date code: A307.
That seems to indicate a 1997 casting date. (87 ??)
I am hoping for a 4 bolt roller cam block...but I may be dreaming??
It does have 191 or 193 swirl port heads and TBI.
I have read that that configuration did appear in some 1995 trucks.
Block also used in crate motors...
One interesting note: the mounting location for a mechanical fuel pump has a plate with 7 bolts holding it in place.
I HOPE thins means that it is machined for a mechanical FP.............
Of course, all will be revealed when I tear the critter apart.........
ed..Now that  I have access to the flat area ahead of the passenger side head, I find the s/n on a sticker: U621xxxx
What the heck does THAT mean??
« Last Edit: October 22, 2018, 03:03:22 PM by Ronno6 »
Offline Ronno6
  • Elder Student
Engine serial #
« Reply #3 on: October 23, 2018, 09:42:47 AM »
The 350 I purchased had a serial # sticker   U621XXXX
Good old 409 washed the number off, so I removed the sticker.
There is no number stamped in the block...just shiny iron.
Do I correctly conclude that:
1. The short block/motor has been rebuilt by an engine rebuilder??
2. The block has been decked, which removed the original s/n ?
« Last Edit: October 23, 2018, 09:44:33 AM by Ronno6 »
Re: Engine serial #
« Reply #4 on: October 23, 2018, 10:14:37 AM »
I would conclude that as well.  No reason to remove the numbers otherwise, unless it is stolen
Re: Engine serial #
« Reply #5 on: October 26, 2018, 07:05:46 PM »
I merged these topics as it appears to be the same subject.
10243880:
Date: 1995-1999
350, 4 bolt, crate engines and ZZ4, roller cam, one piece rear seal
It could also be a L31 Vortec, but the L31 would have 906 or 062 heads.
Based on it being in a 1993 it has been replaced.
You say is has 191 or 193 heads, which one, casting should be under the valve cover.  If they are 193 heads it is a 1995-97 Vortec.
« Last Edit: October 26, 2018, 07:18:25 PM by Captkaos »
Offline Ronno6
  • Elder Student
Re: Engine serial #
« Reply #6 on: November 02, 2018, 07:11:51 PM »
10243880:
Date: 1995-1999
Thanks for your reply.
Not exactly the same subject.
One dealt with the block casting #, which I finally got to see was 10243380.
An 880 block, 1 piece rear main, roller cam ready, 2 bolt main bearings.
The other dealt with the engine serial #, or lack thereof, from the front of the block ahead of the passenger side head.
Had there been one stamped there, it would have narrowed down the original vehicle into which it had been installed.
Again, thank you for your response.
