73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: dumbucket1 on September 12, 2008, 03:05:10 PM
Im putting a set of 062 casting vortec heads off of a 97 chevy silverado half ton onto a 84 350 block. Do I buy a head gasket kit for the 97 truck or a head gasket kit for the 84 truck. Thanks
Go with the head gaskets for the 97
ok cool. Can I reuse the 84 350 head bolts on the vortec heads? also do I use the 84 350 rockers or the vortec rockers? thanks for the info
The head bolts are the same but the valve train componants have to match the newer heads.
yes you'll need the newer rockers and such but I would replace the head bolts.
