73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: Plasticfan on February 20, 2017, 03:41:11 PM
Want to swap out my 2.73 gears for 3.42. Will the 3.42 fit in my 2.73 housing? Are all the pinions 30 spline?
TIA, Don
what year and size is your axle? 12bolt or 10bolt.
All 10 bolts have a 30 spline pinion.
It is the carrier that you want more spline count. Only the later model 1989-1991 10 bolts got 30 spline axle.
Carrier break on a 10 bolt is 2.56 / 2.73
12bolt truck axles all have 30 spline.
Carrier break is 2.73 / 2.76 / 3.42 / 3.73
Mine is a 10 bolt, 8.5" ring gear. Looks like I'm good to go then.
Thanks, Don
