73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: zieg85 on May 27, 2008, 03:32:43 PM
Does anyone have a picture of their frame bracket and z-bar assembly with measurements on the length of the z-bar? I am putting together my extras for the local swap meet next month and don't want to mislead anyone. I parted out this mid 70's truck several years ago of all the stick conversion stuff and from what I remember it is correct. I took out the steering column, pedals, rod to the z-bar, frame bracket and z-bar. All I have is the hydraulic setup up on my mid 80's to compare it to. Thanks in advance.
Do you mean for the clutch?
(http://i6.photobucket.com/albums/y228/Sabaka454/clutch-1.gif)
Yes, looking for actual pics to compare with mine to make sure what I have is from a Chevy. I have parted out many vehicles over the years and don't want to give anyone the wrong stuff. I did part a Ford truck out once but don't think I took the clutch stuff, just the tranny which I sold right away. Thanks.
Post I pic, I can identify it for you.
I will get one tomorrow, Thanks
Chris, here is a couple of pics. Also what years did they have the older splined end on the steering column shaft? Thanks in advance.
That is the correct ones for the pre-83 mechanical setup.
Thanks for the info. Do you know when GM went to the current steering shaft as opposed to the splined version?
My 78 is/ was splined, my Dad's 79 is not.
Cool, thanks so 73-78, then 79-83 and 84-87 for the integrated wiper/dimmer. I appreciate the response back.
Sorry, missed that question completely...
