73-87 Chevy _ GMC Trucks > Projects Posts (NOT VEHICLES)
Body bushing replacement
SUX2BU99:
I chose to replace them because my cab was sagging in the drivers side by 1/4" and it was visible. My wife said it looked bad so I dropped $50 on an Energy Suspension black urethane bushing kit. Note that this kit is for the 73-80 2wd trucks, since my truck for some reason as a 73-80 frame. The 81-up bushings look different and cost about $10 more.
Jacking up the truck under the floor pan, between the gas tank and the body support using wood pieces to spread the load and prevent damaging the floro pan. You can faintly see to the right of the jack where I have removed the stock bushing.
Removed stock bushing. You can see how rusty and corroded they are. It was definitely due for replacement.
This is removal of one of the rear body mount bushings. See how much dirt, rust and dust there was lurking up there?? As soon as I removed the bolt, most of this fell down.
A front stock bushing after removal. Nasty!
A new front bushing in. Get the black urethane bushings, as the red ones can squeak. These will last WAY longer than the crappy OEM rubber ones.
Now this is interesting. This is from the passenger side rad support bushing bolt. It goes through the bushing and attaches with a nut on the bottom. Note the large amount of material missing from the bolt between the threads and the bolt head. This was right where it passed through the factory rubber bushing. It's obvious where moisture sits right in there and eats at the metal. Being near the battery tray doesn't help, since filling a battery can sometimes lead to acid leakage if overfilling it.
Captkaos:
That's what I was looking for. BTW, the bushings you removed were 73-80.
SUX2BU99:
Yep, you got it. That's why I was confuzzed when I originally bought the 81+ bushings and was like "Um, these don't look the same as what I took out." I either do have an earlier frame, or somebody put earlier body supports when they did the resto.
ccz145a:
--- Quote from: SUX2BU99 on August 27, 2008, 12:33:55 PM ---I either do have an earlier frame, or somebody put earlier body supports when they did the resto.
--- End quote ---
Some day someone somewhere will be saying the same thing about my truck with an '84 cab and bed on a '75 frame and new square nose sheetmetal. It would take a bit of brain juice to cipher the steps taken to create this beast.
BTW, I used poly-graphite bushings from PST on mine. They looked like the same thing as your's in the pics, though.
smitty77:
While I'm thinking about this - Does anyone know what size the hole is in the body mount that is riveted to the frame? All of my bolts looked like the one in the last photo. They we so loose that:
1) I thought they we just spinning in the cab when I went to remove them (ie, the threads were stripped in the cab). But no, they we loose enough to turn by hand.
2) All of the excess play generated by the trashed bushings really deformed the hole in 4 out of the 6 body mounts, and will need repair before a body goes back on the frame.
I plan on having my neighbor (a welder by trade) weld a heavy washer to the body mount bracket to make the hole round again, but I need to know the size. I was able to get my hands on washers with a 1 1/8" dia. hole (2" OD) that look like they will work well, but I don't know if this will be too small. One of my good holes looks to be about 1 1/4" dia. How much play is there between the brass bolt sleeve and the body mount?
Thanks,
Smitty
Navigation
[0] Message Index
[#] Next page
Go to full version
