Author Topic: UGH.....Lost Keys  (Read 2766 times)
Offline devildogmech
UGH.....Lost Keys
« on: May 27, 2018, 09:44:14 PM »
So,
I've lost the keys to my 79' C-10..... If I cant find em' I'm going to have to replace the lock cylinder.
Does anyone know of a walk through on how to do it?
I did a google search, but all I get are for newer vehicles....
Be good, but not too good.
Re: UGH.....Lost Keys
« Reply #1 on: May 28, 2018, 07:45:16 AM »
Buy a new lock cylinder and key set and then you need to remove the steering wheel along with all of the components below including the turn signal switch. From there you can access the lock cylinder release which depending on the column you have is an easy process but varies by design. Is the column original and correct for your truck? Just refer to the procedure in the factory service manual for your truck. You will need a lock plate depressor and steering wheel puller to get to it.
http://www.73-87chevytrucks.com/techinfo/7387CKMans//Service/ST_330_79_1979_Chevrolet_Light_Truck_Service_Manual.pdf
« Reply #2 on: May 28, 2018, 02:23:28 PM »
YOU. ARE. AWESOME!!!!!!
« Reply #3 on: May 28, 2018, 11:55:37 PM »
FOUND EM'!!!!
Still ordered the new ignition and door locks.....
« Reply #4 on: May 29, 2018, 04:41:32 PM »
Time to get some spare keys made!
« Reply #5 on: May 29, 2018, 06:09:36 PM »
They are so worn, I really doubt I can. The teeth are just round nubs.....
Offline big_al273
« Reply #6 on: May 29, 2018, 06:15:49 PM »
try a locksmith not the hardware store, locksmith should be able to make you keys, the guy we use at work says i could even bring him a lock cylinder and get a key made from that
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 GMC K1500 winter beater
